9 years, 10 months ago.
Using threads
As you can see in my previous question, mutexes are not working in my platform :( However, threads seem to be working... and I think I need to use them to implement the program I am building, so I am going to risk it and try to use threads without mutexes...
I would appreciate though some advice please on my problem
So far my program uses InterruptIn to activate some processing when a Touch Panel is touched. It is working great. However, when I touch a particular button I need to initiate a processing (make a series of motions with a stepper) If I do it there, it will lock the touch panel until it finishes so I guess I need to initiate a new thread. (I though of using tickers or timeouts.. but I dont know if they will work in this case).
So my question is how do you start (create) or stop (destroy) threads? (actually auto-destroy since the thread had to kill it self once it finishes its processing)
I read the API where the thread seems to be created in the constructor. In the example given in https://developer.mbed.org/handbook/RTOS the thread is created inside main().
How would you do for example if you want to create a thread only when you press the user button??? for example
InterruptIn button(p5);
void startThread() {
    // HERE START THREAD
button.rise(&startThread);
while(1){
//something
Should I use new or something like this?? And how can I make the thread kill it self??
Thank you so much for any help. I really need to complete this and I will appreciate your help
