9 years, 11 months ago.
Taking FFT from mBed using LabVIEW
/media/uploads/groganmatt76/block_diagram.png Hi,
1) I'm trying to take FFT of an input sine wave from a signal generator, connected to the mBed through pin 19 and fed through to LabVIEW using the USB connection. I have a working volt-meter at the moment, but I'm trying to measure the signal quality and do power calculations!
I can make a program that takes FFT of a wave generated from LabVIEW but at the moment I cannot connect the output of the mBed (double) to the spectral measurements block(waveform) as they are incompatible, is there a way to do this?
2) After this, I'd like to input the voltage from a current sensor to another pin on the mBed and have LabVIEW take FFT of both these waves through serial simultaneously, however when I can't find a way to print both signals from the mBed and read them individually on LabVIEW.
/media/uploads/groganmatt76/mbed_code.png /media/uploads/groganmatt76/fft_from_sample_wave.png
can nobody help??
posted by matt grogan 19 Apr 2016
