10 years ago.  This question has been closed. Reason: Off Topic
Following, STM32F4DISCOVERY KIT FOR STM32F407
Hello Mr. Martin Kojtal. Thank you for contact. It will not be recognized by the online IDE. NUCLEO-F411RE, STM32F429I-DISC1 is recognized. I do not know the location of the embed library. It embed to determine the version of the library, how do I. <Note> I do not know English. If you have any rude, please forgive me.
10 years ago.
There is already a placeholder page for this new platform see here. The Arch Max Pro uses the STM32F407VE (see here). Select that platform and you can at least use the online compiler and mbed libs for the F407VE. You should be able to update the firmware on the STLINK part of the Disco board just like for any other mbed nucleo and that should make the drag-drop programming feature available. Just be aware that the flash memory size is not the same and you cant use all of it until the Disco is fully supported: the F407VE has 512K, the F407VG has 1M. Also note the issue with the limited support for the serial port to the host PC. See discussion here.
10 years ago.
The STM32F4DISCOVERY KIT FOR STM32F407 is not available for mbed platform yet. https://developer.mbed.org/platforms/?pvend=10
