10 years, 1 month ago.
What is the problem?
Open On-Chip Debugger 0.10.0-dev-00107-ge4848fe (2015-11-13-11:49) Licensed under GNU GPL v2 For bug reports, read http://openocd.org/doc/doxygen/bugs.html Warn : Interface already configured, ignoring Error: already specified hl_layout stlink Info : The selected transport took over low-level target control. The results might differ compared to plain JTAG/SWD adapter speed: 2000 kHz adapter_nsrst_delay: 100 none separate srst_only separate srst_nogate srst_open_drain connect_deassert_srst Info : Unable to match requested speed 2000 kHz, using 1800 kHz Info : Unable to match requested speed 2000 kHz, using 1800 kHz Info : clock speed 1800 kHz Error: open failed in procedure 'init' in procedure 'ocd_bouncer'
Writes out ChibiStudio. What is the problem?
