11 years ago.
Need Help: A small problem in Clang
I am having a small problem as follows, please help me:
Implement, using LLVM/Clang, to count the number of memory operations executed in a given function (recording reads and writes of fields and arrays elements) of C programs. Here is an example:
int* test(int* b, int* c) { ... for (int i=0; i<10; i++) { a[i] =b[i] + c[i]; } return a; }
After execution of the whole program, the output of the instrumentation should return something like this for each method: "function test: reads = 20; writes = 10".
Thank you very much!
11 years ago.
This isn't in any way related to mbed. You will be better of asking it in a general place (like stackoverflow) or on some LLVM/Clang forums.
