10 years ago.
Using UART together with Touchscreen
Hi Guys,
I am working on a project where I am receiving serial data on UART6_RX. This works perfectly fine.
However, when I add a touchscreen button to the screen and in the main while loop check if it is touched, the UART_RX doesn't receive any data anymore. I've got the feeling that it has something to do with interrupts.
I currently have the following code:
my main() function
    device.baud(31250);
    lcd.Clear(BACK_COLOR);
    Button firstButton(lcd, ts, 10, Y0, btnWidth, btnHeight,LCD_COLOR_RED, BACK_COLOR, "My First Button", Font24);
        if (firstButton.Touched()) //If I remove this if statement, everything works perfectly.
            int n = 10;
       // __disable_irq(); //Tried this, but without succes
        if (device.readable()) {
            char cReceivedByte = device.getc();
            unsigned long result= doSomethingAmazing(cOntvangenByte);
            char buf[10];
            sprintf(buf, "%05lu\r\n", result);
            lcd.SetBackColor(LCD_COLOR_GREEN);
            lcd.SetTextColor(LCD_COLOR_WHITE);
            lcd.SetFont(&Font24);
            lcd.DisplayStringAt(270, LINE(5), (uint8_t *)buf, LEFT_MODE);
      //  __enable_irq();
Which LCD driver are you using?
posted by Jan Jongboom 26 Mar 2016
Hi Jan, I am using the LCD_DISCO_F746NG.h and the TS_DISCO_F746NG.h..
posted by ron de Koster 26 Mar 2016
