11 years ago.
local file system
can a single file in local file system be updated continuously with sensor values connected to the controller?
11 years ago.
I don't believe there is a local file system in V2. You would have to create/use an SD/MMC file system; that you could later transfer via USB/comm port. [ orginally there was a local file system - the same place that you 'dropped' the .bin file.] Gary
