9 years, 9 months ago.
Unable to compile mbed project with gcc
steps:
1) create a new project from a template (Nucleo_ticker) in mbed online compiler for a nucleo board (stm32f303ret6 in my case) 2) export the project for gnu arm gcc 3) download the project 4) edit the Makefile in order to add a linker script 5) run make
compilation result
arm-none-eabi-gcc -mcpu=cortex-m4 -mthumb -mfpu=fpv4-sp-d16 -mfloat-abi=softfp -Wl,--gc-sections --specs=nano.specs -u _printf_float -u _scanf_float -Wl,--wrap,main -Wl,-Map=Nucleo_ticker.map,--cref -T/opt/stm32cubef3/Projects/STM32F303RE-Nucleo/Templates/TrueSTUDIO/STM32F303RE-Nucleo/STM32F303RE_FLASH.ld -o Nucleo_ticker.elf main.o -lstdc++ -lsupc++ -lm -lc -lgcc -lnosys -lstdc++ -lsupc++ -lm -lc -lgcc -lnosys /usr/lib/gcc/arm-none-eabi/5.3.0/../../../../arm-none-eabi/bin/ld: warning: cannot find entry symbol Reset_Handler; defaulting to 0000000008000000 main.o: In function `mbed::Ticker::~Ticker()': /home/clynamen/NUCLEO_TEST/Nucleo_ticker/./mbed/Ticker.h:109: undefined reference to `mbed::Ticker::detach()' /home/clynamen/NUCLEO_TEST/Nucleo_ticker/./mbed/Ticker.h:108: undefined reference to `mbed::TimerEvent::~TimerEvent()' /home/clynamen/NUCLEO_TEST/Nucleo_ticker/./mbed/Ticker.h:110: undefined reference to `vtable for mbed::Ticker' main.o: In function `mbed::Ticker::Ticker()': /home/clynamen/NUCLEO_TEST/Nucleo_ticker/./mbed/Ticker.h:60: undefined reference to `mbed::TimerEvent::TimerEvent()' main.o: In function `mbed::DigitalOut::DigitalOut(PinName)': /home/clynamen/NUCLEO_TEST/Nucleo_ticker/./mbed/DigitalOut.h:49: undefined reference to `vtable for mbed::Ticker' /home/clynamen/NUCLEO_TEST/Nucleo_ticker/./mbed/DigitalOut.h:49: undefined reference to `gpio_init_out' collect2: error: ld returned 1 exit status Makefile:68: recipe for target 'Nucleo_ticker.elf' failed make: *** [Nucleo_ticker.elf] Error 1
It seems that the exported project does not include nor the embed library (something like mbed.a) neither the source code of the library, so compilation cannot be done.
How can I export a project in order to use make?
How strange, looks like you're right, the mbed library is missing for the F303RE.
In the online compiler, if you delete the mbed library and add the mbed-src library, it should provide all of the source files for the mbed library. I was able to successfully compile offline with mbed-src.
