10 years ago.
mbed project on Keil uVision5 has compile error
Hello everyone.
I want to ask how to solve the compile error I currently have.
I am using HRM1017 which has nRF51822 & BLE applications. The firmware of the project based on the sample "BLE_HTM_HRM1017" works fine when I compile it with online compiler. But I would like to use the Keil uVision5 for offline debugging.
So I exported the project setting these params like this. Target: mbed HRM1017 Export Toolchain: Keil uVision4 Then I downloaded & opened the project file, migrated the exported project file to keil uVision5. I set the target device as nRF51822AA which is in my mbed board.
I have got the compile error when I compiled the files. Attached is the result of compile errors. It does not seem to be recognized as cpp files?
I have no idea to deal with this problem. I want to ask you to help me solve the problem.
PS This is my first case to face to the problem of keil compiler. When I did offline debugging with other boards, like mbed 11u24 etc, I had no problem in the same way.
Thank you in advance Marchall
9 years, 11 months ago.
This issue is now fixed.
https://github.com/mbedmicro/mbed/issues/1644
If you update the project with the latest version of the mbed library and the latest ble library then the problem should be fixed.
