9 years, 10 months ago.  This question has been closed. Reason: Off Topic
The camera image display in mycame
Please tell me. capturecycle () We want to display the image from the camera. TFT LCD screen is the grain. Constitution ov7670 without FIFO + NUCLEO-F411RE + TFT ILI9341 [Caution] I do not understand English. It has been translated by Google.
Hello, to display image on TFT you need to apply changes in the main.cpp file:
1) to uncomment this part: //////////// to view camera
my_button.fall(&pressed);
while (1) { capturecycle("/sd/picture.txt"); } }
2) and to comment
//////////// to recognise a target from bmp and target on sd /* epatternmatch("/sd/manchodou.bmp","/sd/manchodou.txt"); while (1) { viewf(); searchp(filename); } }
explanation: my_button.fall(&pressed); is used to declare usage of button: here it is used to capture image and store on SD card from TFT capturecycle("/sd/picture.txt"); run the capture of image from OV7670 in loop and store image in "/sd/picture.txt" when button is pressed.
otherwise just run in loop:
OV7670.CaptureNext() ; TFT.Bitmap(0,0,160,120,bank);
to capture image and display it
Regards
