10 years, 1 month ago.
BLE HID Report Size greater 8bit
Dear Community,
Im trying to write an absolute coordinates mouse or digital pen HID descriptor. I was successful with both, but there is a very restricting limitation, I can not figure out how to resolve. Following descriptor works successful with Windows 8/10 for example for a Digital Pen device:
Digital Pen HID descriptor
0x05, 0x0d, // USAGE_PAGE (Digitizers)
0x09, 0x02, // USAGE (Pen digitizer)
0xa1, 0x01, // COLLECTION (Application)
0x85, 0x01, // REPORT_ID (Digi)
0x09, 0x20, // USAGE (Stylus)
0xa1, 0x00, // COLLECTION (Physical)
0x09, 0x42, // USAGE (Tip Switch)
0x09, 0x32, // USAGE (In Range)
0x15, 0x00, // LOGICAL_MINIMUM (0)
0x25, 0x01, // LOGICAL_MAXIMUM (1)
0x75, 0x01, // REPORT_SIZE (1)
0x95, 0x02, // REPORT_COUNT (2)
0x81, 0x02, // INPUT (Data,Var,Abs)
0x95, 0x06, // REPORT_COUNT (6)
0x81, 0x01, // INPUT (Cnst,Ary,Abs)
0x05, 0x01, // USAGE_PAGE (Generic Desktop)
0x26, 0xff, 0x03, // LOGICAL_MAXIMUM (1023)
0x75, 0x08, // REPORT_SIZE (8) <------------------- 8 = maximum?
0x95, 0x01, // REPORT_COUNT (1)
0x55, 0x0F, // UNIT_EXPONENT (-1)
0x65, 0x11, // UNIT (cm,SI Linear)
0x35, 0x00, // PHYSICAL_MINIMUM (0)
0x46, 0xff, 0x03, // PHYSICAL_MAXIMUM (1023)
0x09, 0x30, // USAGE (X)
0x09, 0x31, // USAGE (Y)
0xc0, // END_COLLECTION
Notice the REPORT_SIZE field for X/Y works only, when its set to maximum 8 bit. Which means I have a resolution from -127 to 127 or unsigned 0-255. For a screen resolution of 1280x720 it is way too less. I want to increase the resolution. I tried to set the field REPORT_SIZE to 0x10, which should be 16bit (also 0x0A, 10 bit). But then no input signals are received on the host (windows 8 or 10), whereas 8bit shows the cursor jumping to absolute coordinates. With Digital Pen I see a bubble kind of cursor.
This is how I send data with 16bit report size using the HIDServiceBase.h class as parent (I took the HID mouse example and modified it):
report
report[0] = 0x01; // report id
report[1] = buttons; // up or down event
report[2] = (uint8_t)(x & 0x00FF);
report[3] = (uint8_t)((x & 0xFF00) >> 8);
report[4] = (uint8_t)(y & 0x00FF);
report[5] = (uint8_t)((y & 0xFF00) >> 8);
send(report);
If its 8bit, Im not shifting the x and y variable bits.
Does somebody know, if there is some kind of 8bit-limitation on the report_size? Or is something wrong with the descriptor or the report above? Can I set the maximum report_size somewhere?
Tips and ideas how to continue are much appreciated! I can test any suggestions.
Thanks!
