10 years, 1 month ago.
MQTT async implementation
Hi all,
I'm trying to get the async version of MQTT to run but fail with the implementation of the callbacks. What I did so far is creating a header for my application with:
CommunicationManager.h
#define MQTTCLIENT_QOS2 1
#include "rtos.h"
#include "ModemManager.h"
#include "MQTTAsync.h"
#define MQTTMGR_SERVERNAME "test.domain"
#define MQTTMGR_SERVERPORT 1883
#define MQTTMGR_CLIENTID "user_001"
#define MQTTMGR_USERNAME "user_001"
#define MQTTMGR_PASSWORD "test1234"
class CommunicationManager {
public:
CommunicationManager();
void run();
private:
MQTT::Async<ModemManager, Countdown, Thread, Mutex>* mqttClient;
void resultHandler(MQTT::Result*);
Then I implemnt this as follows:
CommunicationManager.cpp
#include "CommunicationManager.h"
CommunicationManager::CommunicationManager()
void CommunicationManager::run() {
// Connect to MQTT Broker
MQTTPacket_connectData connData = MQTTPacket_connectData_initializer;
connData.MQTTVersion = 3; // Version 3 = MQTT version 3.1
connData.clientID.cstring = MQTTMGR_CLIENTID;
connData.username.cstring = MQTTMGR_USERNAME;
connData.password.cstring = MQTTMGR_PASSWORD;
connData.keepAliveInterval = 120;
connData.cleansession = 0;
ret = connect(resultHandler, connData);
while (true){
// TO IMPLEMENT
void resultHandler(MQTT::Result* res)
// TO IMPLEMENT
Whit this code I get the following compile errors:
- Incomplete type is not allowed "void resultHandler(MQTT::Result*);"
- Namespace "MQTT" has no member "Result" "void resultHandler(MQTT::Result*)"
- Expected an expression "void resultHandler(MQTT::Result*)"
Any ideas on how to correctly implement the async MQTT version are appreciated! Christoph
I figured it out in the meantime andit seems to work:
#include "CommunicationManager.h" CommunicationManager::CommunicationManager() { mqttClient = new MQTT::Async<ModemManager, Countdown, Thread, Mutex>(modem); } void CommunicationManager::run() { // Connect to MQTT Broker MQTTPacket_connectData connData = MQTTPacket_connectData_initializer; connData.MQTTVersion = 3; // Version 3 = MQTT version 3.1 connData.clientID.cstring = MQTTMGR_CLIENTID; connData.username.cstring = MQTTMGR_USERNAME; connData.password.cstring = MQTTMGR_PASSWORD; connData.keepAliveInterval = 120; connData.cleansession = 0; ret = mqttClient->connect(resultHandler, &connData); while (true){ // To IMPLEMENT } } void resultHandler(MQTT::Async<ModemManager, Countdown, Thread, Mutex>::Result* res) { // TO IMPLEMENT }
