10 years, 1 month ago.
Question regarding HBridge current feedback
Hi Eli,
I am trying to modify ADC code to also read HBridge IFB and IFA signals, but so far without luck.
I am using ADC channel 7 mux A for H bridge A, and channel 3 mux A for H bridge B. I believe this is internally connected to pins PTE23 and PTE22 by default.
I then modified the IRQ handler function state machine to add two new states :
extern "C" void ADC0_IRQHandler()
uint8_t Junk;
switch(CurrentADC_State) {
default:
Junk = ADC0->R[0];
break;
case ADC_STATE_CAPTURE_POT_0:
PotADC_Value[0] = ADC0->R[0];
ADC0->CFG2 &= ~ADC_CFG2_MUXSEL_MASK; //Select the A side of the mux
ADC0->SC1[0] = TFC_POT_1_ADC_CHANNEL | ADC_SC1_AIEN_MASK;
CurrentADC_State = ADC_STATE_CAPTURE_POT_1;
break;
case ADC_STATE_CAPTURE_POT_1:
PotADC_Value[1] = ADC0->R[0];
/* Changed instructions here to prepare for HBridge capture */
CurrentADC_State = ADC_STATE_CAPTURE_I_HBRIDGE_A;
ADC0->SC1[0] = TFC_I_HBRIDGE_0_SENSE_ADC_CHANNEL | ADC_SC1_AIEN_MASK; // HBRIDGE channel
break;
/* NEW STATES */
case ADC_STATE_CAPTURE_I_HBRIDGE_A:
HBridge_0_current_value = ADC0->R[0];
ADC0->SC1[0] = TFC_I_HBRIDGE_1_SENSE_ADC_CHANNEL | ADC_SC1_AIEN_MASK;
CurrentADC_State = ADC_STATE_CAPTURE_I_HBRIDGE_B;
break;
case ADC_STATE_CAPTURE_I_HBRIDGE_B:
HBridge_1_current_value = ADC0->R[0];
ADC0->CFG2 |= ADC_CFG2_MUXSEL_MASK; //Select the B side of the mux
ADC0->SC1[0] = TFC_BAT_SENSE_CHANNEL| ADC_SC1_AIEN_MASK;
CurrentADC_State = ADC_STATE_CAPTURE_BATTERY_LEVEL;
break;
/* Back to the classic code */
case ADC_STATE_CAPTURE_BATTERY_LEVEL:
BatSenseADC_Value = ADC0->R[0];
//Now we will start the sequence for the Linescan camera
TAOS_CLK_HIGH;
for(Junk = 0; Junk<50; Junk++) {
TAOS_SI_LOW;
CurrentLineScanPixel = 0;
CurrentLineScanChannel = 0;
CurrentADC_State = ADC_STATE_CAPTURE_LINE_SCAN;
ADC0->SC1[0] = TFC_LINESCAN0_ADC_CHANNEL | ADC_SC1_AIEN_MASK;
break;
case ADC_STATE_CAPTURE_LINE_SCAN:
if(CurrentLineScanPixel<128) {
if(CurrentLineScanChannel == 0) {
LineScanImage0WorkingBuffer[CurrentLineScanPixel] = ADC0->R[0];
ADC0->SC1[0] = TFC_LINESCAN1_ADC_CHANNEL | ADC_SC1_AIEN_MASK;
CurrentLineScanChannel = 1;
} else {
LineScanImage1WorkingBuffer[CurrentLineScanPixel] = ADC0->R[0];
CurrentLineScanPixel++;
TAOS_CLK_LOW;
TAOS_CLK_HIGH;
} else {
// done with the capture sequence. we can wait for the PIT0 IRQ to restart
TAOS_CLK_HIGH;
TAOS_CLK_LOW;
CurrentADC_State = ADC_STATE_INIT;
//swap the buffer
if(LineScanWorkingBuffer == 0) {
LineScanWorkingBuffer = 1;
LineScanImage0WorkingBuffer = &LineScanImage0Buffer[1][0];
LineScanImage1WorkingBuffer = &LineScanImage1Buffer[1][0];
TFC_LineScanImage0 = &LineScanImage0Buffer[0][0];
TFC_LineScanImage1 = &LineScanImage1Buffer[0][0];
} else {
LineScanWorkingBuffer = 0;
LineScanImage0WorkingBuffer = &LineScanImage0Buffer[0][0];
LineScanImage1WorkingBuffer = &LineScanImage1Buffer[0][0];
TFC_LineScanImage0 = &LineScanImage0Buffer[1][0];
TFC_LineScanImage1 = &LineScanImage1Buffer[1][0];
TFC_LineScanImageReady++;
break;
I have checked the code several times, but now it seems I have broken the battery measurement as well.
I was only able to check HBridge measure for bridge B, because motor A wasn't spinning. I just saw that this is a firmware 2.0 issue, so at least I'll be able to fix that tommorow.
At first sight do you see something wrong with my code ? The only doubt I have is whether I should activate something on the GPIO. I am rather confused at the GPIO code and product documentation that I find rather hard to grasp on this specific point.
Thanks for your help
Ok, I found the issue, I needed to switch line 13 and 14, otherwise it seems the measurement was triggered while I switched the mux. Problem solved
posted by Remi Beges 22 Feb 2016
