10 years, 1 month ago.
Can i change the orientation of the 7" lcd board?
I would like to change the display output orientation (180° rotation) to have the 50-pin connector on the down side. My search in the EAlib for any suggestion (or api) wasnt successful.
Did anyone already implemented a screen rotation successfully? I would be grateful for all hints.
Thank you.
Edit: I found a solution to my request in the emWin library desription (@https://www.lpcware.com/system/files/UM03001_emWin5.pdf). There is a GUI_SetOrientation() -function i looked for :)
