10 years, 1 month ago.
SPI Conflict ?
I use pins PE_12 to PE_15 to write on a SD Card thanks to SDFileSystem Library (using SPI1 I suppose). it works fine. Then I add on the program a compass (COMPASS_DISCO_L476VG). SD Card can't be accessed any more ! Compass is also addressed through SPI, therefore It seems to be on different pins of the microcontroller. Is there a way to have both SD and compass working at the same time?
Thanks
