10 years, 1 month ago.
Is this component tested with FRDM-K64F mbed board? How to connect it to FRDM-K64F mbed board?
10 years ago.
Sorry for late reply. We didn't test with FRDM-K64F. Theoretically this component is compatible with all platforms in mbed. Since the driver library is written using standard mbed API. You can import the example https://developer.mbed.org/teams/Delta/code/NNN40_WiFi/ then compile under FRDM-K64F platform. Regarding to wiring between component and FRDM-K64F. only 3 GPIOs and 4-wire SPI pin are needed. You can reference to the connection with ST NUCLEO.
