10 years, 1 month ago.
Please remove mbed inside the library
Hello Eli,
Could you please remove the mbed library that is inside FRDM-TFC ?
In a project with other libraries that have a dependency on mbed, It is purely and simply breaking the build. The mbed in FRDM-TFC generates conflict with the mbed that any user would add at root level.
Try creating a blank project with FRDM-TFC, BufferedSerial with and without mbed library for instance.
Thanks
Regards
I make your requested changes. Also, the main.cpp was put on the main project webpage for reference.
Thanks for the feedback.
Hi Eli, thank you. I still see the mbed library while importing FRDM-TFC. Are you sure you published after commiting ?
Regards
posted by Remi Beges 11 Feb 2016
Try again.
posted by Eli Hughes 11 Feb 2016
All good, thanks ! And thank you for porting this neat little shield to Mbed.
