9 years, 8 months ago.
LPCExpresso V3 boards w/ PMOD
Is there any reason why the PMOD connector on these Rev 3 boards can not be used? Are the pins mapped, SPI, I2C?
Does the FTDI serial output work as well?
posted by David Thedens 09 Feb 2016
About SPI in PMOD connetor (J3), it shoould just work according to the schematics and pin map for the SPI code.
The I2C in the PMOD connector may not work, since U4 IC is not mounted.
The FTDI signals (P6_4 and P2_1) connects to the chip (same as USBTX and USBRX), so it should work using Serial API.
