10 years, 1 month ago.
Is getNextTxMs() needed for 915Mhz?
In this example the code does:
(uint32_t)dot->getNextTxMs()
(a) Is this needed for US 915MHz? The mdot.h file says it always returns 0.
(b) What is the typical value returned?
Thanks
Anthony,
Like the documentation in mDot.h says, that function is only useful in the EU 868MHz frequency band. In the US 915MHz band, it always returns 0.
In the EU 868MHz frequency band, there are time on air restrictions that the mDot must obey to remain compliant. If the mDot is attempting to rapidly send multiple packets to the gateway, eventually all its available channels will be exhausted (because of the time on air restrictions) and the application will have to wait before it can transmit again. The getNextTxMs function shows how long the application will have to wait until there is a channel available.
Hope this helps.
-Mike
8 years, 10 months ago.
Mike, Have you tried receive example for the EU868 Mhz? doe the time on air restriction affect the receive function of the mdot? Whats the best way to implement it?
Thanks, Abhi
