10 years, 1 month ago.
mbed does not work after exporting to desktop
Hi all, I am doing development mbed code online for my NUCLEO-F446RE. The code is working great. But I am thinking to export everything to my desktop so I can modify and compile the code locally. I find any example (e.g. mbed_blinky) and export it with " Export to desktop IDE" as uVision4. I open the exported project and paste all my code there. I compile without any problem, but when I run it, it doesn't run as expected. I am not sure if it is because I am using uVision5 but the exported one is in uVision4?
Anyway, here is the code I am trying to verify.
DigitalOut myled(LED1);
while (1)
myled = !myled;
wait(1);
It is working great if I compile it online. But wait function doesn't work at all if I compile it locally.
Can you debug the code? It should work. I suspected some problems with floating point support, but you are using wait(1) which should not cause any trouble. If you find out more, please share.
