10 years, 11 months ago.
GSwifi_smtp doesn't complie following error is there an up data
Error: Identifier "GS_DATA_SIZE" is undefined in "GSwifi/GSwifi.cpp", Line: 335, Col: 29 Error: Identifier "GS_DATA_SIZE" is undefined in "GSwifi/GSwifi.cpp", Line: 653, Col: 36
Because, your CPU does not have to test.
GS_DATA_SIZE will be included in the GSwifi_conf.h.
GSwifi_conf.h
#if defined(TARGET_LPC1768) || defined(TARGET_LPC2368) //#define GS_DATA_SIZE 1500 #define GS_DATA_SIZE 1024 #elif defined(TARGET_LPC11U24) #define GS_DATA_SIZE 256 #elif defined(TARGET_KL25Z) #define GS_DATA_SIZE 512 #endif
Please add the code.
#define GS_DATA_SIZE 1000 // adjust by your RAM.
Thanks, Will this work with the STM32F103 Nucleo development kit I plan on hocking it into a GainSpan 2011 device. talk to it over a serial to Wi-Fi connection to see if I can send emails out.
Also have you ever encountered and issue with the NUCLEO DRIVE on your pc it says I have 0 space available. Cant upload bin files to the board any more.
Thanks
Danny
posted by Danny Quaratiello 23 Mar 2015
