11 years ago.
Channel configuration and pin connections?
Hi guys,
I was just wondering what is your channel configuration set to? i.e. what is the pulse repitition frequency, the preamble length, the preambe code and the data rate?
Also I can see what pins you have as the SPI pins and the IRQ pin. But have you any other pins of the DWM1000 connected to the Nucleo besides the power and ground? Maybe the RSTn pin or the wakeup pin?
Thanks in advance.
