11 years, 1 month ago.
build mbed\workspace_tools
Please see following my result.
R:\mbed>python workspace_tools/build.py -m LPC1768 -t ARM
Traceback (most recent call last):
File "workspace_tools/build.py", line 34, in <module> from workspace_tools.build_api import build_mbed_libs, build_lib
File "R:\mbed\workspace_tools\build_api.py", line 20, in <module> import colorama
ImportError: No module named colorama
please help . thanks
11 years ago.
SOLVED!
William, I was having this same issue and also got stuck at "No module named setuptools".
I found this: https://pip.pypa.io/en/latest/installing.html which says the following:
  1. Download this file: https://bootstrap.pypa.io/get-pip.py
  2. Run this code from the same directory as the above file: python get-pip.py (This will install pip and setuptools)
Now you should be able to run this code from the mbed directory: python setup.py install
Run the script install.. It should download required dependencies, although I believe if you have teh latest mbed SDK, colorama is not dependency anymore.
1. mbed SDK is new. 2. how is "Run the script install " thanks
posted by William Chen 09 Mar 2015
Or just run easy_install or pip to install that module which is missing.
posted by Martin Kojtal 09 Mar 2015
fail .. R:\mbed>python setup.py install Traceback (most recent call last): File "setup.py", line 9, in <module> from setuptools import find_packages ImportError: No module named setuptools
11 years ago.
William, You can resolve dependency to colorama like this:
$ pip install colorama
or use git pull to update to latest mbed SDK version where colorama dependency is removed.
Some more info here: http://developer.mbed.org/teams/SDK-Development/wiki/Special:Allpages
On 4/18/2015 I fetched the latest SDK (I think):
git clone https://github.com/mbedmicro/mbed.git         (latest commit is faba4123ec)
and
$ python build.py -m LPC1768 -t ARM
  File "build.py", line 34, in <module>
  File "d:\mbed\workspace_tools\build_api.py", line 20, in <module>
    import colorama
So am I not fetching the correct thing, or is this still a problem? Thanks.
posted by Philip Freidin 19 Apr 2015
