11 years ago.
nRF51822 Puck power consumption
What current draw should I expect for this? I am using virtually the default code and am getting 1.6 mA when advertising, and 1.5 mA when connected with a characteristic being notified once per second.
I'm using the Rigado BMD-200 nRF51822 module which doesn't have a 32 kHz crystal, so I've used the mbed target HRM1017 which also doesn't have a crystal (the nRF51822 mKit Evaluation Board does). However I have managed to get much lower power consumption in the past.
Any ideas what I'm doing wrong. Does ble.waitForEvent() sleep as much as possible?
The Answer!
Ok this took a *lot* of narrowing down, but I eventually found the answer is the logging functionality of Puck. Specifically this line:
#define LOG_LEVEL_INFO
If you comment it out the current consumption goes from 1.4 mA down to 20 uA. I guess this is because it keeps the serial UART peripheral powered if don't.
PLEASE can you add a comment to that line in all your examples noting this? Hopefully it will save other people frustration!
/ Puck Featured
11 years ago.
Hi Tim, I'm one of the authors. Thanks for the feedback!
I've now added warnings in both example_puck_ble and log.h in the puck library in regard to the power usage of serial logging.
Thanks!
posted by Tim H 10 Mar 2015
11 years ago.
could the connection interval be too short?
ble.waitForEvent() is a very light-weight entry into ARM's WFE instructionwhich simply sleeps waiting for system events.
https://developer.mbed.org/teams/Bluetooth-Low-Energy/wiki/Managing-Power-on-mbed-BLE
I don't think it is a BLE issue actually. I added `for (;;) WFE();` to the start of my main() and I still get 1.4 mA consumption. I suspect a timer is started before we even get to main(). I shall take a look at the startup_nrf51822.c code.
posted by Tim H 09 Mar 2015
I found the answer (see edited question; seems you can't answer your own questions for some reason?)
