13 years ago.
how to go from int to char
i have an integer and i want to split this up into 2 chars this doesnt work:
int i=3145; char a[2]; a[0]=(char) i; a[1]=(char)(i >> 8);
anybody has an idea?? thnx
13 years ago.
Why do you think it does not work? I think the code is OK. You could even leave out the typecast. What result did you get in a[]?
13 years ago.
your code is fine, however as your declaration int i =3145 is in decimal, you really need to convert it to hex to see the output. 3145 = c49 in hex, so after execution of the code, a[0]= 49Hex which is 73 and a[1] will be c hex which is 12. This is possibly where the confusion arises.
