11 years ago.
Serial Break Condition
Is there a way to detect a Serial break condition using the RawSerial class without programming my own interrupt handler?
EDIT: If it matters, I am using the LPC1768
11 years ago.
The mbed library does not contain code to detect a Serial Break. So you would need to directly read registers if you need to detect a serial break. I believe the frame error bit is used to detect break conditions if there is no special detection for it.
