10 years, 10 months ago.
Does/When will Ethernet be supported on this board
Hi, does the mbed Ethernet library work on this board? I don't think it has been ported yet, has it? Any time estimate when this will be available?
The Arch Max is an mbed enabled development board for rapid prototyping. It's based on a STM32F407VET6 microcontrolle with an ARM Cortex-M4F core running at 168MHz. It includes an open …
10 years, 8 months ago.
Hi Yihui,
I have bought this board and there is no way to get the Ethernet work. I tried Your example but with no result. The Arch Max takes a timeout after eth.init() or eth.connect() and is walking up to the "break;" and stops because there is no connection. I tried the Sample "Arch_Max_SD_HTTP_Server" with the same mistake. But from Your dependencies with the Sample "HTTP_SDcard_file_server" on a LPC1768 it works fine.
Do You have an idea to help me?
Berry
Hi Berry,
Did you try to use a static IP or Are the LEDs of Ethernet connector turned on? If the board is broken, you can describe the issue on http://www.seeedstudio.com/depot/index.php?main_page=support. Our staffs will look into it.
Yihui
posted by Yihui Xiong 27 Apr 2015
http://developer.mbed.org/users/yihui/code/Arch_Max_Ethernet_Dev/ is a initial try to make Ethernet library work. It doesn't works yet, data is only able to received (UDP data rx example works).
It works now. http://developer.mbed.org/users/yihui/code/Arch_Max_Ethernet_Dev/
It will be integrated into mbed's github repo later.
posted by Yihui Xiong 02 Mar 2015
