11 years ago.
Xbee wireless communication on mbed
i just run a simple code using xbee module on two mbed board, but the receiver cannot get anything, could someone help me solve this problem?
transmitter;
  1. include "mbed.h"
Serial pc(USBTX, USBRX); Serial xbee1(p9,p10); DigitalOut rst1(p30); Digital reset for the XBee, 200ns for reset DigitalOut myled(LED3);Create variable for Led 3 on the mbed
rst1 = 0; Set reset pin to 0 myled = 0;Set LED3 to 0 wait_ms(1);Wait at least one millisecond rst1 = 1;Set reset pin to 1 wait_ms(1);Wait another millisecond
while (1) {Neverending Loop
myled = 1; Turn Led 3 Off int a; a=10; xbee1.printf("%d", a); XBee write whatever the PC is sending xbee1.putc(Y); wait(1); myled = 0; Turn Led 3 on for succcessfull communication wait(1); }
receiver;
  1. include "mbed.h"
Serial xbee1(p9, p10); Serial pc(USBTX, USBRX);
DigitalOut rst1(p30); DigitalOut myled3(LED3); DigitalOut myled2(LED2); DigitalOut myled4(LED4); int main() {
rst1 = 0; Set reset pin to 0 myled2 = 0; myled4=0; wait_ms(1); rst1 = 1; Set reset pin to 1 wait_ms(1); int X;
while (1) { if(xbee1.readable()){ wait(1); xbeel.scanf("%d", &X); myled2 = 1;
xbee1.scanf("%d", &X); X = xbee1.getc(); wait(1); myled2 = 0; if(X==10) {
myled4=1; wait(1);
} else
myled3=1;
-deleted-
11 years ago.
Please see my example: http://developer.mbed.org/users/ebowles/code/LPC4088_xBee/
I prefer the XBee series 2 and use API mode, which helps with message delivery acknowledgement. When you use the Digi XCTU software, be sure to disable CTS and RTS if these pins are not wired. http://www.digi.com/products/wireless-wired-embedded-solutions/zigbee-rf-modules/xctu
Your original code:
DigitalOut rst1(p30); //Digital reset for the XBee, 200ns for reset
DigitalOut myled(LED3); //Create variable for Led 3 on the mbed
rst1 = 0;
Set LED3 to 0 wait_ms(1); //Wait at least one millisecond
rst1 = 1;
Set reset pin to 1 wait_ms(1); //Wait another millisecond
while (1) {  //Neverending Loop
myled = 1; //Turn Led 3 Off
int a; a=10;
xbee1.printf("%d", a); //XBee write whatever the PC is sending
xbee1.putc(Y);
wait(1);
myled = 0; //Turn Led 3 on for succcessfull communication
wait(1);
receiver;
# include "mbed.h"
rst1 = 0; //Set reset pin to 0
myled2 = 0;
myled4=0;
wait_ms(1);
rst1 = 1; //Set reset pin to 1
wait_ms(1);
int X;
while (1) {
wait(1);
myled2 = 1;
X = xbee1.getc();
wait(1);
myled2 = 0;
if(X==10) {
myled4=1; wait(1);
} else
myled3=1;
