11 years ago.
Project exported to LPCXpresso fails to build with linker error
I'm trying to build a project which I exported from the online IDE. I follow the instructions on the following page: https://developer.mbed.org/handbook/Exporting-to-Eclipse-IDEs and try to build the imported project in LPCXpresso (LPCXpresso v7.6.2 [Build 326] [2015-02-02]). It fails with the following error:
14:52:26 **** Incremental Build of configuration Debug for project fvb_spi_test **** make -r all Building target: fvb_spi_test.axf Invoking: MCU C++ Linker arm-none-eabi-c++ -nostdlib -L"C:\Users\ex-vanbever-f\workspace\fvb_spi_test" -L"C:\Users\ex-vanbever-f\workspace\fvb_spi_test\mbed" -L"C:\Users\ex-vanbever-f\workspace\fvb_spi_test\mbed\TARGET_LPC824" -L"C:\Users\ex-vanbever-f\workspace\fvb_spi_test\mbed\TARGET_LPC824\TARGET_NXP" -L"C:\Users\ex-vanbever-f\workspace\fvb_spi_test\mbed\TARGET_LPC824\TARGET_NXP\TARGET_LPC82X" -L"C:\Users\ex-vanbever-f\workspace\fvb_spi_test\mbed\TARGET_LPC824\TARGET_NXP\TARGET_LPC82X\TARGET_LPC824" -Xlinker -Map="fvb_spi_test.map" -Xlinker --gc-sections -mcpu=cortex-m0 -mthumb -T "" -o "fvb_spi_test.axf" ./main.o c:/nxp/lpcxpresso_7.6.2_326/lpcxpresso/tools/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/ld.exe: cannot open linker script file : No such file or directory collect2.exe: error: ld returned 1 exit status make: *** [fvb_spi_test.axf] Error 1 14:52:26 Build Finished (took 345ms)
How can I solve this?
EDIT: this is the project I'm trying to export
Import programfvb_spi_test
basic spi test
10 years, 11 months ago.
Hi Frank,
I was able to get it building with LPCXpresso. There is currently a bug with our exporter and build system that isn't bundling the built mbed library. I've submitted a pull request here: https://github.com/mbedmicro/mbed/pull/1030
Also, due to the limited flash size of the LPC824, your program above won't fit on the device.Here were the final statistics if you're interested:
text data bss dec hex filename 59796 2224 564 62584 f478 fvb_spi_test_lib.axf
Can you publish the program you are trying to export?
posted by Sam Grove 24 Feb 2015I edited my post to include the program I'm trying to export.
posted by Frank Vanbever 25 Feb 2015
