11 years, 1 month ago.
FRDM K64FZ Analog In - PWM issue
Hi, I am trying to use pin A5 of FRDM-K64FZ as an analog input pin. I am getting proper response from all pins from A0 to A3 but it is not giving correct results on A4 and A5. What I have concluded is that these are PWM pins so there must be some issue with that. Can anyone help me getting these pins work as Analog Input pins. I used AnalogIn pin1(A5) declaration for this pin. Thanks in Advance.
11 years ago.
Fahd Ansary wrote:
Thank you very much for the reply. I got it working now. The issue was not swap but ADC pairs. A4 and A5 are 'b' part of ADC pairs and by default 'a' parts are selected. ADC0_CFG2=ADC0_CFG2||0x10; sets the MUXSEL bit in config2 register which selects all 'b' parts of ADCs. A0 to A3 are single ADCs and not pairs so this has no effect on them.
I think A4 and A5 are swapped, seems like a bug. In stead of A4 and A5, try using PTC11 (for A4), and PTC10(for A5). If you look at the "..\mbed\TARGET_K64F\TARGET_Freescale\TARGET_KPSDK_MCUS\TARGET_MCU_K64F\TARGET_FRDM\PinNames.h" file, you will see they declared A4 = PTC10, and A5 = PTC11. This seems to be swapped.
I think this was fixed in the last mbed revision. I checked the latest K64F schematic, available on the net, also the platform page has it defined as that. I used to have older,where they were swapped.
posted by Martin Kojtal 06 Mar 2015
Hi Martin, OK, I just checked on GitHub, and the PinNames.h file was fixed 3 days ago, I guess it must be included with latest v95 that was released 2 days ago. I missed that new release.
posted by modtronix H 06 Mar 2015
posted by Fahd Ansary 09 Mar 2015
