11 years ago.
what to do if I need 8 uart (tx,rx only)?
I need at least 8 uart, is there any platform out there have 8 or more uarts. or any other solution?
11 years ago.
The K64F has 5 UARTs according to its decription, I don't think any will have more than that. Then depending on your requirements (speed of UART, other code running), you can either make software UARTs for the remaining ones, or use SPI<>UART bridge ICs.
Thank you for your answer. Do you know how to use mbed compiler on non mbed board such as stm32f429 discovery which has 8 uarts
posted by Kayhan Kayan 22 Feb 2015
11 years ago.
The MAX14830 is a quad serial UART. Two of those would get you 8 UARTs from an SPI port.
