10 years, 1 month ago.
How to enable Receive Diversity in H5
I'm looking at main.cpp for Dragonfly_Cellular_Ping_example. I see where you can set the APN for the H5 radio. Is there a spot in the code to enable/disable receive diversity?
at#rxdiv?
enable at#rxdiv=1,3
disable at#rxdiv=0,3
Thanks
Jeff
Jeff,
There isn't a function in the Cellular code to do this, but you can use the Cellular::sendBasicCommand or Cellular::sendCommand functions to enable/disable diversity.
Enabling RX Diversity
// send AT command to enable diversity with a 1 second timeout
if (radio->sendBasicCommand("AT#RXDIV=1,3", 1000) != MTS_SUCCESS) {
// failure
} else {
// success
Hope this helps!
-Mike
