11 years, 1 month ago.
How are UUIDs allocated - RedBear UART
I've been trying to OOB my RedBear BLE Nano, and after realising that the beacon example was actually working, moved on to nRF51822_SimpleChat. The nRF Toolbox application for Android reports 'The device does not have required services'. In desperation, I tried the BLE_LoopbackUART and that is correctly recognised. The two examples use differnet UUIDs:
713D0000-503E-4C75-BA94-3148F18D941E (hard coded in the SimpleChat example) 6E400001-B5A3-F393-E0A9-E50E24DCCA9E (the one that works)
Is 'SimpleChat' some made up service in this context? I genuinely have zero interest in the protocol - I just need (at this stage) a UART which is compatible with existing tools, and ideally an end to end IP connection.
11 years ago.
I don't think you'll yet find an IP connection over BLE without some unintentional use of the protocol but here is a UART example that should get you going. HTH!
http://developer.mbed.org/teams/Bluetooth-Low-Energy/wiki/UART-access-over-BLE
