11 years, 1 month ago.
Difference between EM027AS012 and EM027BS013
Hello everybody, Currently V110 ( EM027AS012 ) of the E-Paper panel is no longer used, it is replaced by the V230 ( EM027BS013 ). it seems to have no so much difference between the two revision. PWM is no longer needed and SSEL is divided into SSEL_FLASH and SSEL_EPD. What do you think I need to change in that code to make it work with this kind of screen ?
Thanks Sébastien
