11 years, 1 month ago.
LPC4088 Quickstart board- cannot copy .bin file to E:\mbed drive
hello guys, newby..trying to copy the mbed_blinky_LPC4088.bin file to the designate E:\mbed folder on my hard drive. The LPC4088 board blinks red momentarily, the usb drive appears to be receiving the file, then drive disappears, reappears as if it just detected the USB drive(E:\mbed) . it never copied the .bin file. this happens each time i try to copy the .bin file. I get windows autoplay message, " Open to folder to view files. What could be the problem?
, sincerely, Sonny
check if there is an fail.txt file in the mbed directory. If it is the case there is trouble with your mbed.
To fix it, you probably must use FlashMagic Tool to erase the memory of the mbed.
Look first to this post : http://developer.mbed.org/forum/platform-18-EA-LPC4088-community/topic/5468/
and if it doesn't fix it try with this link :
http://developer.mbed.org/forum/bugs-suggestions/topic/5062/
and at last use flashmagic tool software :
simply download flash magic, and fill the parameters as the picture show (except for the com port wich is probably different).
Hope it can help you.
