11 years, 1 month ago.
FRDM-K64F UART format function
I found an issue in FRDM-K64F Serial library.
To setup an UART port for 115200bps, 8N1, I wrote a code like this;
Serial uart3(PTC17, PTC16); uart3.baud(115200); uart3.format(8, Serial::None, 1);
But uart3 ends up in 115200bps, 8N2.
I digged in the library source code and found;
static inline void UART_HAL_SetStopBitCount(uint32_t baseAddr, uart_stop_bit_count_t stopBitCount) { BW_UART_BDH_SBNS(baseAddr, stopBitCount); }
at mbed-src/targets/hal/TARGET_Freescale/TARGET_KPSDK_MCUS/TARGET_KPSDK_CODE/hal/uart/fsl_uart_hal.h:421.
SBNS bit should be set to 0 for one stop bit -or- 1 for two stop bits. So, this HAL function should be like this;
BW_UART_BDH_SBNS(baseAddr, stopBitCount>>1);
Any comment is appreciated.
Thanks,
I recall I did some fixes (I haven't pushed to main repository yet), si this the one, from my branch:
    uart_stop_bit_count_t stop_count = (stop_bits == 1) ? kUartOneStopBit : kUartTwoStopBit;
    UART_HAL_SetStopBitCount(obj->serial.address, stop_count);
Sounds perfect. I'm looking forward to updating on main branch.
Thanks,
posted by Mitsuo Mizuno 16 Feb 2015
