11 years, 1 month ago.
Using Arch GPRS V2, and the DHT library, Having trouble configuring DHT22 sensor
I'm using the SEN51035P, Grove - Temperature&Humidity Sensor Pro (Seeed Studio) and an Arch GPRS V2 mbed development board.
My output is error 7 = no_patience. I'm using the code below. Any insight or suggestions?
#include "USBSerial.h"
#include "DHT.h"
USBSerial serial;
// defines internal LEDS
DigitalOut myled1(LED2);
DigitalOut myled2(LED3);
DHT sensor(P0_4 , 22);
void blinkRed()
myled1 = 1;
wait(1);
myled1 = 0;
wait(1);
void blinkGreen()
myled2 = 1;
wait(1);
myled2 = 0;
wait(1);
int main(void){
int error = 0;
float f =0.0f;
while(1){
wait(5);
error = sensor.readData();
if (0 == error){
blinkGreen();
f = sensor.ReadTemperature(FARENHEIT);
serial.printf("It's Working!\r\n");
serial.printf("Temperature: %4.2f\r\n",f);
} else {
blinkRed();
serial.printf("Error: %d\r\n", error);
10 years, 6 months ago.
Hi Michael,
Not sure if this question is still active but I just ran into the same problem today.
The problem I had was that the time library does not seem to work on Arch GPRS V2. Inside DHT.cpp you will see:
time_t currentTime = time(NULL);
DigitalInOut DHT_io(_pin);
for (i = 0; i < DHT_DATA_BIT_COUNT; i++) {
bitTimes[i] = 0;
if (!_firsttime) {
if (int(currentTime - _lastReadTime) < 2) {
err = ERROR_NO_PATIENCE;
return err;
} else {
_firsttime=false;
_lastReadTime=currentTime;
So it is checking that currentTime is at least two seconds after _lastReadTime. It does this with the time function. I don't know the details of this function, or its library, or how it works on other platforms... but I do know it just does not work on my Arch GPRS V2. Regular printouts show that it just stays on 0. Now, 0 - 0 = 0 < 2, so the check will always fail and you will get ERROR_NO_PATIENCE.
(Actually, the first time it runs, you will probably get a different error, due to the _firsttime check.)
I got around this by commenting out the check. A bit dirty but it will do the job for the moment!
