11 years, 1 month ago.
CMSIS-DAP Debugging and USBHID
Started up trying debugging with Keil / uVision and CMSIS-DAP. Got everything working quite OK. Had some headache why my app stopped in the beginning - but found the info about semi-hosting calls - and removed "mbed-mac_address()" and other file-system calls and then it is running fine. Until I'm trying to debug what I have issues with - USBHID communication. Is USBHID communication ("hid.readNB()") also a semi-host call ?? The debugger gets disconnected at the very moment I'm trying to talk USB to the unit my normal way (over USBHId that is). The error message is: "AGDI Cortex-M: Cannot access target, Shutting down debug session." I do understand that running two USB connections (CMSIS-DAP over the built in USB and one over USBHId on pin P31/P32 could mess up - but could you explain why ?? And is there any way for me to debug this at all ?? My issue is that sometimes USB communication is stalled - maybe an error in a I2C communcation... Thanks Henrik
Hi, did you manage to resolve this issue? I also can not debug with uVision. Tried both v4 and v5, but get the same debug message as you "Cannot access target, Shutting down debug session."
