10 years, 1 month ago.
MBED under Eclipse with Cross ARM GCC
I exported a project as described in https://developer.mbed.org/handbook/Exporting-to-Make to compile it with Eclipse.
The eclipse project is configured to use the GNU Tools for ARM Embedded Processors :
/media/uploads/HumuZ/settings.jpg
When I build the project, I get a lot of warnings related to SVCALL as well as errors error: unknown type name 'class'. This makes make think that the build process tries to compile everything as if they was only C code and not C++ as well.
I don't understand why as the makefile differentiate C and C++ files:
makefile extract
AS      = $(GCC_BIN)arm-none-eabi-as
CC      = $(GCC_BIN)arm-none-eabi-gcc
CPP     = $(GCC_BIN)arm-none-eabi-g++
LD      = $(GCC_BIN)arm-none-eabi-gcc
OBJCOPY = $(GCC_BIN)arm-none-eabi-objcopy
OBJDUMP = $(GCC_BIN)arm-none-eabi-objdump
SIZE    = $(GCC_BIN)arm-none-eabi-size
Any idea on how I could solve that? Thank you
