11 years, 1 month ago.
Compatibility with F411RE
Is this compatible with F411RE? I see that the Hello world example uses some conditionals #elif defined(TARGET_LPC1768) to define the EthernetInterface.
Hi Daniel, I also like to know. It couldn't get any Ethernet shield working on this Nucleo board sofar. Regards, Jack.
posted by Jack Berkhout 09 Feb 2015
I had to connect the WIZ SPI pins to the Arduino SPI pins. Like this:
    SPI spi(D11, D12, D13); // mosi, miso, sclk
    EthernetInterface eth(&spi, D10, D7); // spi, cs, reset
    spi.format(8,0); // 8bit, mode 0
    spi.frequency(7000000); // 7MHz
posted by Daniel Blendea 15 Feb 2015
Nucleo F411 of ST has also same initialization. I think all nucleo board could use the code of serial and SPI init.
Use it at main:
    Serial pc(USBTX, USBRX);
    pc.baud(115200);
    SPI spi(SPI_MOSI, SPI_MISO, SPI_SCK); // mosi, miso, sclk
    EthernetInterface eth(&spi, PB_6, PA_9);//, nRESET(p9); // reset pin is dummy, don't affect any pin of WIZ550io
    wait(1); // 1 second for stable state
I found similar one in http://developer.mbed.org/teams/EthernetInterfaceW5500-makers/code/WIZnet_PPPoE/ please refer this. and our collegue have NUCLEO_F401 Board so i ask him to add it. maybe he answer again of his work.
#elif defined (TARGET_NUCLEO_F030R8)
    pc.baud(115200);
#elif defined (TARGET_NUCLEO_F334R8)
    pc.baud(115200);
#endif
Quickly scanning through it I don't see a reason why it shouldn't work. Where did you find the #ifdef part?
In Websocket_Ethernet_HelloWorld_W5500/main.cpp
posted by Daniel Blendea 10 Feb 2015
Those are just example pinouts in the HelloWorld program. In your program replace them with the pins you are using.
posted by Erik - 10 Feb 2015
Ok, thanks. I wouldn't want to buy the shield only to discover that I can't use it with my F411RE.
I don't have the shield or the F411 myself, so I cannot give you any guarantees, only that I don't see any problems in the code.
