10 years, 2 months ago.
LSE Clock and mbed initialisation
I am working with Nucleo F103RB and i am trying to set the clock to LSE. For that i am using this lib https://developer.mbed.org/users/kenjiArai/code/Nucleo_RTC_Clock_setting/
When running the code it says that LSE is already configured. What i am not understanding is how is it possible? 1 - Does mbed per default configure LSE? If yes where is the code for that?
I also checked this file
but maybe i am overlooking something.
2 - How does the initialisation on mbed works? Does it run even before the main() method?
10 years, 1 month ago.
The nucleo's use an automated selection process to choose the correct clocks. In case of the main clock for example a first attempt is to use an external clocksource (HSE_EXT), then try to use the external xtal generator (HSE_XTAL), finally try to use the internal RC clockgenerator (HSI). See system_st32f1xx.c The RTC clocks will do something similar. All of this is indeed executed before main() starts as part of the booting process.
