10 years, 2 months ago.
How to activate by ABP example application and loriot.
Hello, I am having a heck of a time trying to connect my LoRa end device to the network.
First off I haven't figured out what the example app is even doing. From what I can assume is just sends a pkt on boot. Here is my console output:
======== DEBUG STARTED
Frame to be sent: 44 02 91 3A 30 75 0A 1C B2 72 64 4D 00 65 70 3D 6C 6F 72 61 44 65 76 69 63 65 06 6C 74 3D 33 30 30 03 62 3D 55 FF 3C 2F 33 2F 30 2F 30 3E 2C 3 C 2F 33 2F 30 2F 31 3E 2C 3C 2F 33 2F 30 2F 32 3E 00 00 00 00 00 LED1 = 00000001 LED1 = 00000000
Setup:
I am using the example LMIC application, configured for 915MHz and have a mutitech conduit gateway. I am using the community version of loriot for the LoRa service provider. I have been able to succesfully connect the gateway to loriot portal and can see that it connects. I have configured this for 915Mhz as well.
I tried various attempts to add devices. My understanding is that the free community version only supports ABP and not over the air.
in the sampleapp in the loriot portal I am presented with EUI DevAddr APPKEY NWKSKEY APPSKEY
Can someone please tell me what constants I need to change with what? Please confirm all items above are to be entered in big endian?
Specifically, what is LORAWAN_NET_ID
Separate question. I can't find any tools to debug the why the network is failing to join. I assume that if the example app is sending a pkt that the gateway is probably rejecting it. Does anyone have any debug tips?
Have you found ansers to your questions? I am in the same situation
posted by Alejandro Veiga 19 Feb 2016
Yes, I aborted this project but I did get it to work by playing with the endianess. I think I had to reverse it for the DevAddr but leave it for the Keys.
posted by Mathieu Schneider 19 Feb 2016
