13 years ago.
what is pow?
hello i found this code:
  altitude = (float)44330 * (1 - pow(((float) pressure/p0), 0.190295));
but mbed doesnt want to accept this, i get:
"more than one instance of overloaded function "pow" matches the argument list:" in file "/main.cpp", Line: 67, Col: 42
" function "std::pow(float, int)"" in file "/"
" argument types are: (float, double)" in file "/"
anbody has an idea? thanx in advance!
13 years ago.
Try this:
altitude = (float)44330 * (1 - pow( (float)(pressure/p0), 0.190295) );
It's subtle, but this says the entire expression, "pressure/p0," is float, rather than just "pressure."
was a shot, but it didnt work
posted by Adriaan Van Steendam 16 Mar 2013
Did you see this one?
http://mbed.org/forum/mbed/topic/476/
Particularly Simon's comment?
posted by Aaron Minner 17 Mar 2013
thnx, indeed, it works
posted by Adriaan Van Steendam 17 Mar 2013
13 years ago.
the problem is the function pow needs an integer, but i want my exponent is 0.190295 is there an other function then power??
13 years ago.
Instead of casting pressure/p0 as a float, cast it as a double.
float altitude = (float)44330 * (1 - pow(((double) (pressure/p0)), 0.190295));
Tim
You can also declare that your exponent is a float:
float altitude = (float)44330 * (1 - pow(((float) (pressure/p0)), (float)0.190295))
http://www.cplusplus.com/reference/cmath/pow/
The standard library function pow does not have a mixed float/double or double/float input overloading. What you originally typed caused pressure/p0 to be a float while your exponent was interpreted as a double by the compiler. Explicitly declaring either the base as a double and letting the exponent be interpreted as a double, or declaring both as floats clears up the problem.
posted by Tim Zuercher 17 Mar 2013
