10 years, 3 months ago.
F446RE PWM
Hi, i wrote simple PMW program but it seems it works only for pin PB_3. If i change to other PMW port (for example PA_7) nothing happens.
PwmOut mpwm(PB_3);
    mpwm.period(1.0f);
    mpwm.write(0.50f);
Could, someone explain it to me ? Thanks
10 years, 2 months ago.
I wonder if this problem solved or not. I have the same problem and have no idea why only PB3 works.
Unfortunately i still don't know why is that. Maybe it's a bug in the software.
posted by James Jhceiw 31 Jan 2016
Do you have anything attached to the board? Did you try any additional PWM outputs other than PA_7?
Board is connected to several stepper motor drivers, i have tried to use other PMW outputs but only PB_3 works fine. The board is out of the box, not modified in any way. I wonder, do i have to connect any solder bridge ?
posted by James Jhceiw 29 Dec 2015
