10 years, 3 months ago.
Having some problems with connect example code
i loaded the LoRa connect example code and changed the 3 values to match my configuration( which i verified work when i have the AT cmd set code running and node red) However, this program doesnt seem to work. I am sure i am missing something here. I can no longer communicate thru tera term and see nothing on the mdot debug ser line. Anyone have any suggestions ? Glenn...
The MultiConnect® mDot™ offers significantly longer range and improved radio performance compared to traditional wireless solutions—resulting in greater transmission range and reduced capital expense.
Glenn,
Can you share your mDot's configuration as well as your Conduit's configuration and firmware version?
-Mike
posted by Mike Fiore 16 Dec 2015
Mike you will have to forgive my ignorance here, i am not exactly sure of all the config so here is what the conduit is set for and i only changed the mdot network key and pass phrase. everything else was left as is in the mdot. let me know what else you need to know aep firmware 1.0.33 lora enabled staic lan Fz 915 FSB 1
posted by marra glenn 16 Dec 2015
