10 years, 3 months ago.
what happen with PA2 and PA3?
Hello. I am a super beginner in mbed and I hope somebody can help me.
I wrote a program to count with a 7seg. this is the program
#define IOS (0xA0) // PA_5 + PA_7
#define MASK (0xFF) // Pins 0,1,2,3,4,5,6,7
PortOut myIOs(PortA, MASK);
//PortOut my7Seg(PortA,MASK);
//values of the LEDs
int leds[10]={
0b11000000,
0b11111001,
0b10100100,
0b10110000,
0b10011001,
0b10010010,
0b10000010,
0b11011000,
0b10000000,
0b10010000
while(1){
for(int i=0;i<10;i++){
// myIOs=leds[i];//0;
//myIOs=0b01111111;
myIOs=0b00000000;
//my7seg=leds[i];
//my7Seg
wait(0.5); // 500 ms
}//for
}//while
for some reason all Port A pins work except PA2 and PA3.(Now i am turning on ALL pins PA0PA7 but they dont work) And I cant find why. Can someone tell me if there is something special about these pins and how to solve this problem.
It is handy to mention the board you have. PA2 and PA3 are also the pins used for connecting via the USB Serial, and the pins on the board are by default not connected. If you want to use them anyway you need to place a jumper somewhere, the Nucleo user guide should mention it if I am correct.
Thanks for the answer. I am using the F091RC. After searching for an answer in the docs, finally I got something similar to what you said but not with USB but with USART. It seems they are disconnected and that depends on jumpers SB62 SB63 SB13 and SB14.
Are there any other pins with this "special" behavior that I should be aware of?
Thanks again , very much appreciated
posted by 16 Dec 2015
One year later I can comment on this. PA2 and PA3 are not connected. Also PA13 ans PA14 are not recommended to use. And PC14 and PC15 also have some issues.
posted by Cristian Fuentes 27 Apr 2017
