10 years, 1 month ago.
it possible to achieve both Ethernet and pin interrupt(interruptIn)?
Hello
I have developed using this board. I want to use EthernetInterface and interruptIn but the program will freeze before running and blink error LEDs. What can I do?
If it blinks error LEDs you should have a message on the serial terminal why it is blinking them (probably because your InterruptIn pin is not supported. Did you try it without the Ethernet?).
