10 years, 3 months ago.
Only one definition can be set in "Compile Macros" field.
When I use online compiler on IE11 or Chrome, only one definition can be set in "Compile Macros" field in the "Compile" menu, because it doesn't accept CR(Enter) in the field. When I use firefox, I can specify multiple definitions in "Compile Macros" field.
I expect to work it well on Chrome.
The current workaround will be to paste strings from other editor.
Thank you.
10 years, 1 month ago.
This is now fixed.
