10 years, 4 months ago.
pyOCD support missing?
Resolved the issue of pyocd not working, despite having a merge saying 'adds python 3 support' it isn't actually supported, redownloaded it for python 2 and it runs but it still doesn't work. Using the sample blinky program:
arm-none-eabi-gdb seeed_blinky.elf GNU gdb (GDB) 7.10 __snip__ Reading symbols from seeed_blinky.elf...done. (gdb) target remote localhost:3333 Remote debugging using localhost:3333 0x0800a22a in ?? () (gdb) load Loading section .text, size 0x73a8 lma 0x8000000 Loading section .ARM.exidx, size 0x8 lma 0x80073a8 Loading section .data, size 0xb8 lma 0x80073b0 Start address 0x8000690, load size 29800 Transfer rate: 5 KB/sec, 1752 bytes/write. (gdb) continue Continuing. ^C Program received signal SIGINT, Interrupt. 0x08008ab0 in ?? () (gdb) step Cannot find bounds of current function (gdb) continue Continuing. ^C Program received signal SIGINT, Interrupt. 0x08008ab0 in ?? ()
The program doesn't run (the LED never lights up), there shouldn't be anywhere near 0x8000 instructions in a simple blinky program, can't step because it 'cannot find bounds of current function' and no instructions are decoded. Blinky has been compiled with debug enabled so it's not an issue with that.
I've installed pyOCD and exported my program for debugging to my local drive (and compiled it) but it seems contrary to the message on the wiki and device page here: 'SWD debug with GDB+ pyOCD/OpenOCD, Keil or IAR', there is no support for this board in pyOCD.
INFO:root:Unsupported board found: b'9011'
INFO:root:Target could not be determined. Specify target manually to use board
Override target to debug. Supported targets are: k64f,
lpc1768, k22f, kinetis, kl26z, nrf52, kl05z,
stm32f051, kl46z, k20d50m, w7500, max32600mbed, nrf51,
cortex_m, lpc4330, maxwsnenv, kl28z, lpc11xx_32,
lpc11u24, stm32f103rc, kl02z, kl25z, lpc800
None of these appear to be compatible with the arch max, so how is GDB debugging possible with this board?
Updated:
Sorry to make you confused. The PyOCD's flash download function for the Arch Max is not implemented yet. But we can use PyOCD to debug with arm-none-eabi-gdb (assume we use gcc arm embedded toolchain).
1. create elf file with debug info
make DEBUG=1
2. download bin file using drag-n-drop programming
3. setup a gdb server using pyocd (the latest pyOCD from - https://github.com/mbedmicro/pyOCD), the mcu - stm32f407 is not added to pyocd yet, so we use stm32f103rc
pyocd -t stm32f103rc
4. use arm-none-eabi-gdb to connect the gdb server
arm-none-eabi-gdb example.elf -ex 'target remote localhost:3333'
The program I used is:
blinky snippet
DigitalOut led(LED1);
while (1) {
led = !led;
wait(1);
Then we can debug the program in gdb console:
mon reset
b main.cpp: 8
c
c
OK thanks for the help, I've now got basic debugging working... Is there a timeframe for proper debugging support though?
Debugging in this way doesn't support a lot of things such as backtraces, variable outputting, and is a bit unstable.
posted by 12 Dec 2015Before we get it fully supported by pyOCD, we can try using OpenOCD as gdb server. With the latest openocd and a openocd config file (https://github.com/Seeed-Studio/Arch_Max/blob/master/arch_max.cfg), we can easily setup a gdb server.
posted by 13 Dec 2015If you use windows, we can use the powerful EmBitz IDE with Arch Max (https://github.com/Seeed-Studio/Arch_Max/wiki/Get-Started-with-EmBitz-and-Seeed-Arch-Max)
edited question instead
posted by Bob Seque 08 Dec 2015
