10 years, 4 months ago.
many mbed compile errors with this assembly listing
were you successful in running this through the mbed 2.0 compiler?? It seems several "$label" might be missing or misaligned. Gary
Helo Gary,
I don't say that i have a successfull run throught mbed Compiler. all that i said is that it compile perfectly andd run under the keil IDE development tool. The question is how to include a file in assembly. Can you explain the $label missing or missalign. If you use Gcc you need to add a function directive for each xrunname. Thanks
My apologies, I had not read your earlier posts/questions. I jumped straight to the code and imported it.
in fiddling around with the mbed compiler - i was getting messages about adding a 'pad' value
to make Thumb instructions come out correctly - is my assumption. [I thought it was in reference to
a missing label for a Forth-word]
Gary
